Старый 15.12.2011, 00:09   #2
glibs is offline
glibs
Сотрудники компании It Box
4,942 / 911 (40) +++++++
Джоб
static void glibs(Args _args)
    TmpAccountSum       tmpAccountSum1,
                        tmpAccountSum2;
    Counter             i;
    FreeText            text;
    Counter             startTime;
    #Define.cycles(1000)
    startTime = WinAPI::getTickCount();
    for (i = 0; i <= #cycles; i++)
        tmpAccountSum1.clear();
        tmpAccountSum2.clear();
        text = int2str(i);
        tmpAccountSum1.AccountNum = strrep("0", 20 - strlen(text)) + text;
        tmpAccountSum2.AccountNum = strrep("0", 20 - strlen(text)) + text;
        tmpAccountSum1.Balance01 = 999999 * 888888;
        tmpAccountSum2.Balance01 = 999999 * 888888;
        tmpAccountSum1.Balance02 = 999999 * 888888;
        tmpAccountSum2.Balance02 = 999999 * 888888;
        tmpAccountSum1.Balance03 = 999999 * 888888;
        tmpAccountSum2.Balance03 = 999999 * 888888;
        tmpAccountSum1.Balance04 = 999999 * 888888;
        tmpAccountSum2.Balance04 = 999999 * 888888;
        tmpAccountSum1.Balance05 = 999999 * 888888;
        tmpAccountSum2.Balance05 = 999999 * 888888;
        tmpAccountSum1.Balance06 = 999999 * 888888;
        tmpAccountSum2.Balance06 = 999999 * 888888;
        tmpAccountSum1.Balance07 = 999999 * 888888;
        tmpAccountSum2.Balance07 = 999999 * 888888;
        tmpAccountSum1.Balance10 = 999999 * 888888;
        tmpAccountSum2.Balance10 = 999999 * 888888;
        tmpAccountSum1.TaxCode = "XXXXXXXXXXXXXXXXXXXX";
        tmpAccountSum2.TaxCode = "XXXXXXXXXXXXXXXXXXXX";
        tmpAccountSum1.CurrencyCode = "XXX";
        tmpAccountSum2.CurrencyCode = "XXX";
        tmpAccountSum1.Posting = 1;
        tmpAccountSum2.Posting = 1;
        tmpAccountSum1.Dimension[1] = "XXXXXXXXXXXXXXXXXXXX";
        tmpAccountSum2.Dimension[1] = "XXXXXXXXXXXXXXXXXXXX";
        tmpAccountSum1.Dimension[2] = "XXXXXXXXXXXXXXXXXXXX";
        tmpAccountSum2.Dimension[2] = "XXXXXXXXXXXXXXXXXXXX";
        tmpAccountSum1.Dimension[3] = "XXXXXXXXXXXXXXXXXXXX";
        tmpAccountSum2.Dimension[3] = "XXXXXXXXXXXXXXXXXXXX";
        tmpAccountSum1.OperationsTax = 1;
        tmpAccountSum2.OperationsTax = 1;
        tmpAccountSum1.TransDate = today();
        tmpAccountSum2.TransDate = today();
        tmpAccountSum1.Txt = "XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX" +
                             "XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX";
        tmpAccountSum2.Txt = "XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX" +
        tmpAccountSum1.SortDate = today();
        tmpAccountSum2.SortDate = today();
        tmpAccountSum1.Balance01Cur = 999999 * 888888;
        tmpAccountSum2.Balance01Cur = 999999 * 888888;
        tmpAccountSum1.Qty01 = 999999 * 888888;
        tmpAccountSum2.Qty01 = 999999 * 888888;
        tmpAccountSum1.Qty02 = 999999 * 888888;
        tmpAccountSum2.Qty02 = 999999 * 888888;
        tmpAccountSum1.Qty03 = 999999 * 888888;
        tmpAccountSum2.Qty03 = 999999 * 888888;
        tmpAccountSum1.Voucher = "XXXXXXXXXXXXXXXXXXXX";
        tmpAccountSum2.Voucher = "XXXXXXXXXXXXXXXXXXXX";
        tmpAccountSum1.insert();
        tmpAccountSum2.insert();
    info (strfmt("%1", (WinAPI::getTickCount() - startTime) / 1000));
    i = 0;
    while select tmpAccountSum1
    join tmpAccountSum2
        where tmpAccountSum1.AccountNum == tmpAccountSum2.AccountNum
        text = tmpAccountSum1.Voucher + tmpAccountSum2.Voucher;
        i++;
    info (strfmt("%1", i));
    i = 0;
        while select tmpAccountSum2
            where tmpAccountSum2.AccountNum == tmpAccountSum1.AccountNum
            i++;
glibs®
За это сообщение автора поблагодарили: mazzy (5), sukhanchik (3), Logger (15).
временная таблица, оптимизация, полезное, производительность
Как правильно именовать временные таблицы Владимир Максимов DAX: Программирование 22 17.05.2011 21:03
Временные таблицы и их временные файлы AraraT® DAX: Прочие вопросы 6 12.04.2010 00:39
Не страшно ли временные таблицы временно сделать постоянными? Gustav DAX: Программирование 11 09.02.2006 11:04
Временные таблицы vasiliy DAX: Программирование 6 09.11.2004 11:04
Временные таблицы в запросе Dron AKA andy DAX: Программирование 4 06.09.2002 12:14
Часовой пояс GMT +3, время: 22:13.
