Старый 10.10.2012, 16:31   #3
Raven Melancholic is offline
Raven Melancholic
Аватар для Raven Melancholic
2,164 / 1296 (48) ++++++++
Если в DAX4 (насколько помню в Ax3.0 было так же), то как-то так:
private boolean fillInventsTable(SysRecordTemplateDescription _sysTemplateDescription)
    SysRecordTmpTemplate    tmpTemplateTbl;
    SysRecordTemplateTable  sysTemplate;
    container               recordValues;
    container               curRecord;
    ItemId                  itemId;
    TableId                 tableId;
    Counter                 idx;
    sysTemplate = SysRecordTemplateTable::find(tableNum(InventTable));
    if (!sysTemplate)
        throw error("Нет шаблонов для таблицы номенклатур.");
    itemId  = "" ;
    delete_from tmpTemplateTbl;
    SysRecordTmpTemplate::insertContainerSimple(tmpTemplateTbl, condel(sysTemplate.Data, 1, 1));
    select firstOnly tmpTemplateTbl
        where tmpTemplateTbl.Description    == _sysTemplateDescription
    recordValues    = tmpTemplateTbl.data;
    for (idx = 1; idx <= conLen(recordValues); idx++)
        [tableId, curRecord]    = conPeek(recordValues, idx);
        switch (tableId)
            case tableNum(InventTable)          :
                inventTable.clear();
                this.fillFields(inventTable, curRecord);
                inventTable.ItemId  = itemId;
                inventTable.doInsert();
                break;
            case tableNum(InventTableModule)    :
                inventTableModule.clear();
                this.fillFields(inventTableModule, curRecord);
                inventTableModule.ItemId  = itemId;
                inventTableModule.doInsert();
                break;
            case tableNum(InventItemLocation)   :
                inventItemLocation.clear();
                this.fillFields(inventItemLocation, curRecord);
                inventItemLocation.ItemId  = itemId;
                inventItemLocation.doInsert();
                break;
    return true;
где fillFields:
private boolean fillFields( Common      _common,
                            container   _fileds,
                            boolean     _onlyEditableOnCreateFields = false,
                            boolean     _allowDublicates = true
    SysDictField    dictField;
    Set             excludeValidateField;
    container       valueSet;
    fieldId         fieldId;
    Counter         infologLines;
    Counter         idx;
    boolean         doClear;
    excludeValidateField    = new Set(Types::Integer);
    infologLines = infolog.line();
    for (idx = conLen(_fileds); idx; idx--)
        valueSet    = conpeek(_fileds, idx);
        fieldId     = conpeek(valueSet, 1);
        dictField   = new SysDictField(_common.TableId, fieldId);
        if (dictField
            && (dictField.allowEditOnCreate() || !_onlyEditableOnCreateFields)
            && (_allowDublicates || !dictField.isUnique()))
            _common.(fieldId)   = conpeek(valueSet, 2);
            if (!excludeValidateField.in(fieldId) && !_common.validateField(fieldId))
                doClear             = true;
                _common.(fieldId)   = nullValue(conpeek(valueSet, 2));
    if (doClear)
        infolog.clear(infologLines);
    return true;
В DAX2009 набор таблиц отличается. Кроме того, могут использоваться другие классы.
За это сообщение автора поблагодарили: raniel (1).
Как программно создать строку номенклатуры??? Сергей Щербак DAX: Программирование 25 02.09.2011 11:45
Контейнер в строку. В одну строку. HorrR DAX: Программирование 3 01.09.2009 14:10
Создание нескольких экземпляров Word на основе шаблона axaLearner DAX: Программирование 5 03.01.2005 16:12
"Закупка на основе заказов" или "сводное планирование" Hamster DAX: Функционал 2 17.02.2004 01:47
HELP!!! Как создать неуникальнцю метку в Axapta 3.0??? Maxim Gorbunov DAX: Программирование 3 14.04.2003 12:29
Часовой пояс GMT +3, время: 12:41.
