ax-erp: Delete AUC File Of Users
Источник: http://microsoft-dynamics-ax-erp.blo...-of-users.html
============== X++: static void ClearAucFileForUsers(Args _args) { System.Array files; int fileCount; int i; str nextFile; str path = "C:\\Users"; str Finalpath; str pattern = "*.auc"; container listOfFiles; int DirCount; System.Array Directories; int j; str nextDir; container listOfDir; FileIOPermission dirPermission, filePermission; InteropPermission interopPermission; Set permissionSet; new InteropPermission(InteropKind::ClrInterop).assert(); listOfDir = conNull(); listOfFiles = connull(); Directories = System.IO.Directory::GetDirectories(path); if(Directories) { DirCount = Directories.get_Length(); for(j=0; j < DirCount; j++) { nextDir = Directories.GetValue(j); Finalpath = nextDir + "\\AppData\\Local"; listOfDir += Finalpath; } } j=0; DirCount = conLen(listOfDir); while( j < conLen(listOfDir)) { j++; Finalpath = conPeek(listOfDir,j); try { files = System.IO.Directory::GetFiles(Finalpath, pattern); } catch { continue; } if (files) { fileCount = files.get_Length(); for(i=0; i < fileCount; i++) { nextFile = files.GetValue(i); System.IO.File::Delete(nextFile); info(nextFile); } } } CodeAccessPermission::revertAssert(); } Источник: http://microsoft-dynamics-ax-erp.blo...-of-users.html
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. Последний раз редактировалось Poleax; 30.10.2012 в 11:53. Причина: оформление |
| Теги |
| auc, кеш, чистка |
