Старый 23.07.2015, 14:07   #10
raniel is offline
raniel
Аватар для raniel
241 / 11 (1) +
Да сделал. И получил подробности ошибки ... когда нажимаю вторую ссылку http://xxx.xxxxx.ru/MicrosoftDynamic...svc?singleWsdl получаю вот такой ответ
The service encountered an error.
An ExceptionDetail, likely created by IncludeExceptionDetailInFaults=true, whose value is:System.NotSupportedException: A single WSDL document could not be generated for this service. Multiple service contract namespaces were found (http://schemas.microsoft.com/netfx/2009/05/routing, http://tempuri.org). Ensure that all your service contracts have the same namespace. at System.ServiceModel.Description.WsdlHelper.VerifyContractNamespace(List`1 wsdls) at System.ServiceModel.Description.WsdlHelper.GetSingleWsdl(MetadataSet metadataSet) at System.ServiceModel.Description.ServiceMetadataExtension.EnsureSingleWsdlInitialized() at System.ServiceModel.Description.ServiceMetadataExtension.HttpGetImpl.TryHandleMetadataRequest(Message httpGetRequest, String[] queries, Message& replyMessage) at System.ServiceModel.Description.ServiceMetadataExtension.HttpGetImpl.ProcessHttpRequest(Message httpGetRequest) at SyncInvokeGet(Object , Object[] , Object[] ) at System.ServiceModel.Dispatcher.SyncMethodInvoker.Invoke(Object instance, Object[] inputs, Object[]& outputs) at System.ServiceModel.Dispatcher.DispatchOperationRuntime.InvokeBegin(MessageRpc& rpc) at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage5(MessageRpc& rpc) at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage31(MessageRpc& rpc) at System.ServiceModel.Dispatcher.MessageRpc.Process(Boolean isOperationContextSet)
401, service, soap, сервис
Проблема балансировки в кластере AOS Ivanhoe DAX: Администрирование 26 29.07.2015 16:19
workflowax: The Request Failed with HTTP status 401: Unauthorized Blog bot DAX Blogs 0 20.09.2011 23:12
emeadaxsupport: HTTP 401 Error when trying to deploy/create an Enterprise Portal site on a load balanced farm using a hardware load balancer Blog bot DAX Blogs 0 06.05.2010 03:16
Проблема с созданием объекта Lelya DAX: Администрирование 33 27.06.2005 16:38
Часовой пояс GMT +3, время: 18:03.
