Старый 27.01.2019, 15:14   #8
Stitch_MS is offline
Stitch_MS
Аватар для Stitch_MS
397 / 483 (17) +++++++
Еще пример. Класс SubledgerJournalizerProjectExtension,
    protected ProjEmplTrans createProjHourTrans(Container _projectActualHeaderContainer, SourceDocumentLineItem _sourceDocumentLineItem, ...)
        ProjEmplTrans   projEmplTrans;
        PSAComponentGroupAssignment psaComponentGroupAssignment;
        projEmplTrans.clear();
        #declareProjectActualHeaderContainerVariablesMacro
        #projectActualHeaderContainerMacro = _projectActualHeaderContainer;
        projEmplTrans.ProjId = actualProjectId;
        projEmplTrans.CategoryId = actualCategoryId;
        projEmplTrans.ActivityNumber = actualActivityNumber;
        projEmplTrans.LinePropertyId = actualLinePropertyId;
Два макроса в коде выглядят так:
    #localmacro.declareProjectActualHeaderContainerVariablesMacro
        RefRecId            actualSourceDocumentLine;
        DataAreaId          actualProjectDataAreaId;
        ProjId              actualProjectId;
        ProjCategoryId      actualCategoryId;
        smmActivityNumber   actualActivityNumber;
        ProjLinePropertyId  actualLinePropertyId;
        CurrencyCode        actualTransactionCostCurrency;
        CurrencyCode        actualTransactionSalesCurrency;
        CurrencyCode        accountingCurrency;
        ProjTaxGroup        actualTaxGroupId;
        ProjTaxItemGroup    actualTaxItemGroupId;
        DimensionDefault    actualDefaultDimension;
        Qty                 actualQuantity;
        AmountCur           actualTransactionCurrencyCostAmount;
        AmountMST           actualAccountingCurrencyCostAmount;
        AmountCur           actualTransactionCurrencySalesAmount;
        AmountMST           actualAccountingCurrencySalesAmount;
    #endmacro
    #localmacro.projectActualHeaderContainerMacro
        actualSourceDocumentLine,
        actualProjectDataAreaId,
        actualProjectId,
        actualCategoryId,
        actualActivityNumber,
        actualLinePropertyId,
        actualTransactionCostCurrency,
        actualTransactionSalesCurrency,
        accountingCurrency,
        actualTaxGroupId,
        actualTaxItemGroupId,
        actualDefaultDimension,
        actualQuantity,
        actualTransactionCurrencyCostAmount,
        actualAccountingCurrencyCostAmount,
        actualTransactionCurrencySalesAmount,
    #endmacro
Т.е. в методе createProjHourTrans первый параметр _projectActualHeaderContainer -- это, по сути, 17 параметров. Если изменить макросы, то список параметров в createProjHourTrans вроде как не изменился, возможно не будет считаться за breaking change, и может по-тихому сломать расширение, изменяющее значение одного из элементов в контейнере.
И в этом классе такой метод не один.
d365fo
cleverax: D365FO: Using Bar codes, External codes and GTIN in Warehouse app to identify an item. Blog bot DAX Blogs 0 03.02.2018 21:13
cleverax: D365FO: Manual inbound load rating Blog bot DAX Blogs 0 03.02.2018 21:13
patrickmouwen: Dynamics 365 CRM and ERP interaction Blog bot DAX Blogs 0 29.12.2017 03:11
Изменение книги покупок\продаж, журнал учета счетов фактур - когда выйдет обновление? Elenko DAX: Функционал 32 24.12.2014 10:52
Обновление detail-таблицы DreamCreator DAX: Программирование 1 05.04.2005 15:57
Часовой пояс GMT +3, время: 11:55.
