Старый 19.08.2019, 14:07   #12
kair84 is offline
kair84
Сорри если неправильно понял проблему, но на счет запроса вроде бы все просто :
PHP код:
declare @HIERARCHYrecid bigint 68719485163
select
    t1
.DIMENSIONATTRIBUTEVALUESET
,STUFF((SELECT '-' t16.NAME
            FROM DIMENSIONATTRIBUTE t16
                JOIN DIMENSIONHIERARCHYLEVELVIEW
as t17
                        on t17
.DIMENSIONATTRIBUTE t16.RECID
                        where
                        t17
.HIERARCHYrecid = @HIERARCHYrecid
               ORDER BY t16
.RECID
FOR XML PATH('')), 11'')  as ConcatDimNames
,STUFF((SELECT '-' + -- t6.NAME +
ISNULL(
STUFF((SELECT '-' t3.DisplayValue
                    from DimensionAttributeValueSetItemView
as t3
                    where
                    t1
.DimensionAttributeValueSet t3.DimensionAttributeValueSet
and t7.DIMENSIONATTRIBUTE t3.DIMENSIONATTRIBUTE
), 11''
'N/A')
FROM DIMENSIONATTRIBUTE t6
as t7
                    on t7
.DIMENSIONATTRIBUTE t6.RECID
                    where
                    t7
           ORDER BY t6
.RECID
FOR XML PATH('')), 11'') as ConcatValues
 from DimensionAttributeValueSetItemView t1
   join DIMENSIONHIERARCHYLEVELVIEW t4
 on t4
.DIMENSIONATTRIBUTE t1.DIMENSIONATTRIBUTE
  where
        t4
 group by t1
к стати один из блоков ORDER BY .. FOR XML PATH - был лишний, т.к. в DimensionAttributeValueSetItemView для DimensionAttributeValueSet, DIMENSIONATTRIBUTE - не будет повторений.
За это сообщение автора поблагодарили: raz (10), wojzeh (5).
computed column, dimensions, regular expressions, sql, view
ax_gfm_framework_team: Dimension defaulting in accounting distributions, Part 4 - Fixed dimensions and handling of empty dimension values Blog bot DAX Blogs 0 20.12.2013 23:11
ax_gfm_framework_team: Dimension defaulting in accounting distributions, Part 3 - Splitting and defaulting using Financial dimension default templates and Main account allocation rules Blog bot DAX Blogs 0 18.12.2013 09:11
sumitsaxfactor: Replacing Financial Dimension in Ledger Dimension Blog bot DAX Blogs 0 19.01.2012 13:11
daxline: Set financial dimension values through code in AX 2012 Blog bot DAX Blogs 0 18.11.2011 02:26
Khue Trinh: Setting up a link between a financial dimension and the site inventory dimension Blog bot DAX Blogs 0 27.09.2010 13:05
Часовой пояс GMT +3, время: 04:43.
