Старый 11.02.2020, 16:57   #1
RSrd is offline
RSrd
AX2012 R3 WMDP, Разрешить ввод "<" в поля web-формы (ошибка "A potentially dangerous Request.Form value was detected from the client")
Доброго дня!
AX2012 R3 Warehouse Mobile Device Portal, IIS 8
Коллеги, есть необходимость разрешить ввод в поля web-формы коды маркировки, иногда содержащие символ "<", т.е. напомишающие html-тэги.
При отправке формы получаем ошибку: "A potentially dangerous Request.Form value was detected from the client"
Как отключить эту валидацию?
Правки web.config не помогают.
A potentially dangerous Request.Form value was detected from the client (IC="<asdf").
Description: ASP.NET has detected data in the request that is potentially dangerous because it might include HTML markup or script. The data might represent an attempt to compromise the security of your application, such as a cross-site scripting attack. If this type of input is appropriate in your application, you can include code in a web page to explicitly allow it. For more information, see http://go.microsoft.com/fwlink/?LinkID=212874.
Exception Details: System.Web.HttpRequestValidationException: A potentially dangerous Request.Form value was detected from the client (IC="<asdf").
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[HttpRequestValidationException (0x80004005): A potentially dangerous Request.Form value was detected from the client (IC="<asdf").]
System.Web.HttpRequest.ValidateString(String value, String collectionKey, RequestValidationSource requestCollection) +324
System.Web.HttpRequest.ValidateHttpValueCollection(HttpValueCollection collection, RequestValidationSource requestCollection) +239
System.Web.HttpRequest.get_Form() +50
System.Web.HttpRequestWrapper.get_Form() +10
System.Web.Mvc.FormValueProvider..ctor(ControllerContext controllerContext) +36
System.Web.Mvc.FormValueProviderFactory.GetValueProvider(ControllerContext controllerContext) +32
System.Web.Mvc.<>c__DisplayClass6.<GetValueProvider>b__1(ValueProviderFactory factory) +34
System.Linq.WhereSelectEnumerableIterator`2.MoveNext() +164
System.Linq.WhereSelectEnumerableIterator`2.MoveNext() +87
System.Collections.Generic.List`1..ctor(IEnumerable`1 collection) +387
System.Linq.Enumerable.ToList(IEnumerable`1 source) +54
System.Web.Mvc.ValueProviderFactoryCollection.GetValueProvider(ControllerContext controllerContext) +251
System.Web.Mvc.ControllerBase.get_ValueProvider() +30
System.Web.Mvc.ControllerActionInvoker.GetParameterValue(ControllerContext controllerContext, ParameterDescriptor parameterDescriptor) +62
System.Web.Mvc.ControllerActionInvoker.GetParameterValues(ControllerContext controllerContext, ActionDescriptor actionDescriptor) +105
System.Web.Mvc.ControllerActionInvoker.InvokeAction(ControllerContext controllerContext, String actionName) +311
System.Web.Mvc.Controller.ExecuteCore() +105
System.Web.Mvc.ControllerBase.Execute(RequestContext requestContext) +42
System.Web.Mvc.ControllerBase.System.Web.Mvc.IController.Execute(RequestContext requestContext) +10
System.Web.Mvc.<>c__DisplayClass8.<BeginProcessRequest>b__4() +31
System.Web.Mvc.Async.<>c__DisplayClass1.<MakeVoidDelegate>b__0() +16
System.Web.Mvc.Async.<>c__DisplayClass8`1.<BeginSynchronous>b__7(IAsyncResult _) +10
System.Web.Mvc.Async.WrappedAsyncResult`1.End() +50
System.Web.Mvc.MvcHandler.EndProcessRequest(IAsyncResult asyncResult) +28
System.Web.Mvc.MvcHandler.System.Web.IHttpAsyncHandler.EndProcessRequest(IAsyncResult result) +9
System.Web.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +549
System.Web.HttpApplication.ExecuteStepImpl(IExecutionStep step) +132
System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +163
Старый 12.02.2020, 05:08   #2
online
Pandasama
467 / 140 (5) +++++
а в какой-то момент при вводе заменять на &lt &gt - не получится?
Старый 27.02.2020, 15:19   #3
RSrd is offline
RSrd
Нет, к сожалению, заменять не получится, потому что нужно сканировать уже наклеенные на товарах коды, в том числе, приходящие от поставщиков.
WHS (2012 R3) ошибка при логине Logger DAX: Программирование 5 30.04.2015 22:48
Ошибка при выборе поля "подразделение" на форме Дима DAX: Программирование 5 01.10.2007 11:23
Ошибка при настройке прав доступа поля "Используется" журнала ордеров Zepp DAX: Администрирование 2 22.06.2007 15:35
Pokluda: Outbound web service (AIF) Blog bot DAX Blogs 0 28.10.2006 17:43
Часовой пояс GMT +3, время: 17:44.
