Старый 07.10.2021, 13:24   #1
Ventainais is offline
Ventainais
SSRS report retrieving field metadata error
Hello all!
I have an ssrs report which uses data provider classes and temp tables for data.
In the temporary table I added a new string field, I synchronized the table, compiled the DP classes and it's controller class (additionally used compile forward).
The problem I have is, when I deploy the report through Ax management shell, I get an error:
Publish-AXReport : The AXRDCE extension caught an unexpected exception for repo
rt SalesQuotation.
The error message was:
An exception occurred when retrieving the field metadata for the field Name_LF
in table SalesQuotationDetailsTmp.
The report has more then one design, I use the new added string field in one design and the deploy command finishes without errors, but when I add the same new field in my other design, I get the above mentioned error.
I think I tried everything what I could come up in with, AOS and reporting services restart won't help.
Does anyone else have an idea what I could try?
axapta 2012, field metadata, report deploy exception, ssrs
dynamicsaxse: November 2018 Release – Dynamics AX2012 R3 update Blog bot DAX Blogs 0 15.11.2018 09:11
bojensen: Dynamics AX 2012 error when running SSRS-reports just after deleting a table field from report’s temporary table – Addicted2AX / Addicted2SQL Blog bot DAX Blogs 0 09.01.2013 17:11
emeadaxsupport: Error viewing an SSRS Report from Microsoft Dynamics AX 2009 - Sys.WebForms.PageRequestManagerServerErrorException: An unknown error occured while processing the request on the server Blog bot DAX Blogs 0 22.03.2012 02:13
Часовой пояс GMT +3, время: 17:30.
