Старый 08.10.2021, 13:20   #4
sukhanchik is offline
sukhanchik
Аватар для sukhanchik
3,343 / 3563 (125) ++++++++++
Сообщение от Ventainais Посмотреть сообщение
Thank You for the response.
step 4. remove DP class from report.
I understand that if I remove the DP class from the report, then I have to delete the report textboxes in them, because they are referencing the data, do I understand that right?
There are 2 options.
1. It is enough to delete the class, save and close the report. Then add the DP class again. The report will work.
2. Remove the class, then clear all field references to fields, save and close the report. Then add the DP class and manually re-reference the fields.
The DP class must be removed from the report. It won't work without it. But I usually had enough of option 1
Последний раз редактировалось sukhanchik; 08.10.2021 в 22:54.
axapta 2012, field metadata, report deploy exception, ssrs
dynamicsaxse: November 2018 Release – Dynamics AX2012 R3 update Blog bot DAX Blogs 0 15.11.2018 09:11
bojensen: Dynamics AX 2012 error when running SSRS-reports just after deleting a table field from report’s temporary table – Addicted2AX / Addicted2SQL Blog bot DAX Blogs 0 09.01.2013 17:11
emeadaxsupport: Error viewing an SSRS Report from Microsoft Dynamics AX 2009 - Sys.WebForms.PageRequestManagerServerErrorException: An unknown error occured while processing the request on the server Blog bot DAX Blogs 0 22.03.2012 02:13
Часовой пояс GMT +3, время: 16:58.
