Старый 27.10.2005, 16:29   #4
AndyG is offline
AndyG
Руководство разработчика:
During export and import, tables and classes are handled differently than other application object.
When you export a table or a class, only the members (fields, field groups, indexes, relations, and methods) that have been created or modified in the layer you are exporting from are included in the export.
When you later import such objects, you should make sure that the Delete table and class members check box is not selected.
As opposed to tables and classes, application objects like forms, reports, and queries are always fully exported. This means that for example all methods, controls and so on are exported, whether or not they have been created or modified in the current layer.
ax3.0
Владельцы таблиц в БД аксапты AxaptaUser DAX: Администрирование 11 23.05.2007 18:33
Экспорт слоя USR st_msav DAX: Администрирование 2 10.02.2006 13:56
Программынй экспорт из определенного слоя Vasilenko Alexsandr DAX: Программирование 14 08.12.2005 15:07
траблы при выделении черным цветом и указанием слоя изменения кода... NetBus DAX: Программирование 8 14.07.2005 18:31
Экспорт/импорт таблиц IT-specialist DAX: Администрирование 15 26.02.2005 20:46
Часовой пояс GMT +3, время: 01:43.
