Старый 09.06.2010, 14:10   #1
ZooY is offline
ZooY
Аватар для ZooY
379 / 46 (2) +++
Angry Ошибка выполнения запроса - система не находить запись
CRM 4.0
С помощью SOAP-запроса пытаюсь квалифицировать интерес.
Делаю так:
var xmlhttp = new ActiveXObject("Microsoft.XMLHTTP");
var soapXml = "<?xml version='1.0' encoding='utf-8'?>" +
	"<soap:Envelope xmlns:soap='http://schemas.xmlsoap.org/soap/envelope/' " +
	"xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance' " +
	"xmlns:xsd='http://www.w3.org/2001/XMLSchema'>" +
	GenerateAuthenticationHeader() +
	"<soap:Body>" +
	"<Request xsi:type='SetStateLeadRequest' xmlns='http://schemas.microsoft.com/crm/2006/WebServices'>" +
	"<EntityId>" + leadId + "</EntityId>" +
	"<LeadState>Qualified</LeadState>" +
	"<LeadStatus>3</LeadStatus>" +
	"</Request>" +
	"</soap:Body>" +
	"</soap:Envelope>";
try {
	xmlhttp.open("POST", "/mscrmservices/2006/CrmService.asmx", false);
	xmlhttp.setRequestHeader("SOAPAction", "http://schemas.microsoft.com/crm/2006/WebServices/Execute");
	xmlhttp.setRequestHeader("Content-Type", "text/xml; charset=utf-8");
	xmlhttp.setRequestHeader("Content-Length", soapXml.length);
	xmlhttp.send(soapXml);
	var result = xmlhttp.responseXML.xml;
	if (result.indexOf('faultcode') < 0)
		crmForm.SubmitCrmForm(1,true,true,false);
	else
		alert(result);
} catch(e) {
	alert(e.description);
На выходе получаю вот такой вот запрос:
<soap:Envelope xmlns:soap='http://schemas.xmlsoap.org/soap/envelope/' xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance' xmlns:xsd='http://www.w3.org/2001/XMLSchema'>
	<soap:Header>
		<CrmAuthenticationToken xmlns="http://schemas.microsoft.com/crm/2007/WebServices">
			<AuthenticationType xmlns="http://schemas.microsoft.com/crm/2007/CoreTypes">0</AuthenticationType>
			<CrmTicket xmlns="http://schemas.microsoft.com/crm/2007/CoreTypes"></CrmTicket>
			<OrganizationName xmlns="http://schemas.microsoft.com/crm/2007/CoreTypes">MyOrg</OrganizationName>
			<CallerId xmlns="http://schemas.microsoft.com/crm/2007/CoreTypes">00000000-0000-0000-0000-000000000000</CallerId>
		</CrmAuthenticationToken>
	</soap:Header>
	<soap:Body>
			<EntityId>{3ADEC8AB-466A-DF11-BE5B-00155D6F6500}</EntityId>
		</Request>
	</soap:Body>
</soap:Envelope>
Интерес 100% существует, имя организации правильное, но в результате получаю вот такую ошибку:
<?xml version="1.0"?>
<soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<soap:Body>
<soap:Fault>
<faultcode>soap:Server</faultcode>
<faultstring>Server was unable to process request.</faultstring>
<detail>
<error>
<code>0x80040217</code>
<description>lead With Id = 3adec8ab-466a-df11-be5b-00155d6f6500 Does Not Exist</description>
<type>Platform</type>
</error>
</detail>
</soap:Fault>
</soap:Body>
</soap:Envelope>
У кого-нибудь есть идеи почему такое может быть?
Ошибка авторизации при выполнении запроса Dark_Angel Dynamics CRM: Разработка 0 03.09.2009 17:23
Закешированная ошибка доработок (ISV) после выполнения импорта организации. Alberto Farinacci Dynamics CRM: Администрирование 4 06.07.2009 16:12
Ошибка при записи продукта e.pasechny Dynamics CRM: Администрирование 2 03.03.2008 18:12
Ошибка в отчете "Каналы продаж" после изменения процесса продаж Артем Enot Грунин Dynamics CRM: Разработка 2 25.09.2007 09:59
Ошибка при установке MS CRM Outlook клиента flay Dynamics CRM: Администрирование 0 29.06.2006 10:16
Часовой пояс GMT +3, время: 22:23.
