Старый 17.06.2010, 15:05   #1
workflowax: Reset Delegate Due Date
Источник: http://workflowax.wordpress.com/2010...gate-due-date/
Dynamics AX 2009 workflow has functionality built in by default to delegate work-items to new users. But what happens if your workitem is about to escalate when you delegate? The new assignee may only have a very short time to action the item. So if you want to reset the due date time of work-items on delegation, here is a quick and dirty way to get it right. Be warned, this is modifying a framework class so you will need to be careful when upgrading.
Class SysWorkflowEventDispatcher::onWorkitemDelegate
//Declare Variable (line 23)WorkflowDateTimeTemp _dueDate;//Generate and set new due date (approx line 114) after Setting description, before notifying assignee_dueDate = SysWorkflowProviderService::resolveDueDate(_workItemContext.parmWorkflowCorrelation().parmWorkflowContext(), stepTable.StepId, workItemTable.UserId);workItemTable.DueDateTime = DateTimeUtil::newDateTime(_dueDate.parmWorkflowDate(), _dueDate.parmWorkflowTime());//notify the assigneenotification = EventNotificationWorkflow......Happy Daxing
ax2009, workflow
workflowax: What is a workflow owner used for? Blog bot DAX Blogs 0 01.06.2010 15:05
workflowax: Enabling Workflow Configurations for different modules Blog bot DAX Blogs 0 23.05.2010 08:06
crmdude: Find User with least number of Tasks due on a Date Blog bot Dynamics CRM: Blogs 0 27.01.2010 02:08
daxsol: Axapta Kernel Functions Blog bot DAX Blogs 1 16.05.2009 19:22
Часовой пояс GMT +3, время: 02:05.
