Старый 28.09.2010, 22:05   #1
25,644 / 848 (80) +++++++
Dynamics AX Sustained Engineering: Advance Holder functionality not available without Finance II license
Источник: http://blogs.technet.com/b/dynamicsa...i-license.aspx
Problem:
When attempting to select an Advance Holder as an offset type in a journal when not licensed for Finance II, the list of Advance Holders is empty.
Resolution:
When not licensed for Finance II it is not possible choose Advance Holder employee in a General Journal. This is due to the relation “\DataDictionary\Tables\LedgerJournalTrans\Relations\OffsetEmplTable_RU\LedgerJournalTrans.OffsetCompany == EmplTable.dataAreaId”. This relation is incorrect as “LedgerJournalTrans.OffsetCompany" will not exist in the database as field “OffsetCompany” is dependent on the Financial II License key. Removing the relation “LedgerJournalTrans.OffsetCompany==EmplTable.dataAreaId” in the table “LedgerJournalTrans” Advance Holder information will be properly shown.
Dynamics AX Sustained Engineering: Error when opening EU Sales List form when not licensed for Project Blog bot DAX Blogs 0 25.08.2010 01:05
Dynamics AX Sustained Engineering: Microsoft Dynamics AX 4.0 and AX 2009 are compatible with Microsoft Windows 7 and Microsoft Windows Server 2008 R2 Blog bot DAX Blogs 0 22.09.2009 04:06
Dynamics AX Sustained Engineering: Upgrade script ReleaseUpdateDB41_Invent\updateInventItemPrice () fails without LogisticsAdvanced license code Blog bot DAX Blogs 0 07.07.2009 03:05
Dynamics AX Sustained Engineering: Dynamics AX 2009 Patching Blog bot DAX Blogs 0 08.10.2008 10:05
Часовой пояс GMT +3, время: 16:16.
