Старый 08.11.2010, 22:06   #1
25,644 / 848 (80) +++++++
East Ocean - Technical: Error installing outlook client: Cannot delete a subkey tree because the subkey does not exist
Источник: http://eastoceantechnical.blogspot.c...nt-cannot.html
"Could not remove registry subkey HKEY_CURRENT_USER\SOFTWARE\Microsoft\MSCRMClient\AllowList. Cannot delete a subkey tree because the subkey does not exist."
I come across this error during the installation of Outlook client MSCRM 4.0
If you faced the same problem as me, most probably is you have install outlook client beta 2010 before.
Solution:
Make sure the Beta 2010 outlook client was uninstalled,
uninstall version 4 outlook client; if any
Manually delete the folder Program Files\MSCRM
Reinstall the CRM 4 outlook client again.
This time it should work like charm :)
East Ocean - Technical: The RSA key container could not be opened Blog bot Dynamics CRM: Blogs 0 02.11.2010 13:05
East Ocean - Technical: No organization was specified in the configuration file Blog bot Dynamics CRM: Blogs 0 18.10.2010 10:05
East Ocean - Technical: Always focus on solutions, not on problems. Blog bot Dynamics CRM: Blogs 1 13.10.2010 16:25
East Ocean - Technical: Error during installation of CRM Outlook Client for Office 2010 Blog bot Dynamics CRM: Blogs 0 10.09.2010 13:05
East Ocean - Technical: The path is not of a legal form - Data Migration Manager Blog bot Dynamics CRM: Blogs 0 11.08.2010 11:05
Часовой пояс GMT +3, время: 19:28.
