Старый 03.12.2010, 01:13   #1
daxdilip: Troubleshooting - AOS Restart
Источник: http://daxdilip.blogspot.com/2010/12...s-restart.html
Issue:
In Dynamics AX 2009, I modified an existing table to add 2 new fields, as usual I did a db synch on that table so that the table definition is updated.
Came back to my program which is a class which populates this table. Somehow, the values were not getting populated in these 2 new fields. Whatever, I tried but the program (my class) simply doesn't update my two new fields. Even, I went to the extent of hard coding these field values, but still it doesn't put any values in the table for those two new fields. Went into debugger mode and watched the tables populating the fields properly but after the insert statement still the values for those 2 new fields are not updated.
Solution:
After struggling for 30 mins, finally gave up and did an AOS restart and there you go! the values now get updated
daxdilip: Tip: How to display the AOS Name at the status bar Blog bot DAX Blogs 5 15.11.2010 13:55
daxdilip: Object Server 01: Internal Error occured executing stored procedure when creating session for the AOS Blog bot DAX Blogs 0 29.09.2010 18:05
daxis: Troubleshooting blocked SPIDS in AOS Blog bot DAX Blogs 0 01.04.2009 18:05
Dianne Siebold: Restart AOS When Service WSDL Contains an Enum Blog bot DAX Blogs 0 16.12.2008 06:09
Вылетает аxапта 4.0 при завершении работы Delfins DAX: Прочие вопросы 5 27.06.2007 15:43
Часовой пояс GMT +3, время: 17:30.
