Старый 20.07.2011, 08:12   #1
25,644 / 848 (80) +++++++
daxdilip: Troubleshooting AOS Service Startup Error Object Server 01 The specified schema name DBO either does not exist
Источник: http://daxdilip.blogspot.com/2011/07...e-startup.html
Few days back, one of my AOS Services won't start. In the Event Viewer, I found this error message:
Error 1 - Object Server 01 The database reported session 1 AOS [Microsoft][ODBC SQL Server Driver][SQL Server]The specified schema name DBO either does not exist
Solution - After some troubleshooting, Found that this was due to the Collation change at SQL Server level which was made sometime back for testing Chinese characters.
Changed the Collation back to the default collation of SQL Server and now AOS Service started.
SQL Collations is a whole new world which I explored a while ago. Will be writing a detailed post soon on that. Watch out this space!
daxdilip: Dynamics AX Troubleshooting AOS Error Internal Error occured executing stored procedure when creating session for the AOS Blog bot DAX Blogs 0 23.12.2010 07:11
daxdilip: Object Server 01: Internal Error occured executing stored procedure when creating session for the AOS Blog bot DAX Blogs 0 29.09.2010 18:05
daxdilip: Troubleshooting AX 2009 Enterprise Portal Error The type or namespace name "Portal" does not exist in namespace 'Microsoft.Dynamics' Blog bot DAX Blogs 0 12.08.2010 11:05
Часовой пояс GMT +3, время: 18:47.
