Старый 24.07.2011, 14:14   #1
axaptacorner: Not enough rights to use table 'Signature log' (SIGSignatureLog)
Источник: http://axaptacorner.blogspot.com/201...use-table.html
“Not enough rights to use table 'Signature log' (SIGSignatureLog).”
(Some time this problem is occurred when we want to see record info of any record)
SOLUTION: After installing AX5 SP1, it creates a new configuration key which it leaves unticked. go into Administration > Setup > System > Confiugration and tick the Electronic Signature tick box
good luck!!!!!!
dax-lessons: Deactivating configuration key will not affect the table any more [Dynamica AX 2012] Blog bot DAX Blogs 1 06.07.2011 08:17
palleagermark: Not enough rights to use table 'Common' (Common) error i Purchase Totals (PurchTotals) Blog bot DAX Blogs 0 07.06.2011 19:11
emeadaxsupport: Error “Not enough rights” when you select Category in Electronic Time Card Blog bot DAX Blogs 0 03.04.2010 05:15
Not enough rights to use table 'Officials - Report lines' (OfficialsTrans_RU). почему нет прав? rusalaudinov DAX: Программирование 4 18.02.2008 10:41
Часовой пояс GMT +3, время: 00:12.
