Старый 16.03.2012, 07:11   #1
Dynamics AX Sustained Engineering: Announcing Compatibility Certification of Safari 5.1.2 with Dynamics AX 2012
Источник: http://blogs.technet.com/b/dynamicsa...s-ax-2012.aspx
Dynamics AX Sustained Engineering is proud to announce the following compatibility:
Product
Dynamics AX Version
Apple Safari 5.1.2 on Windows and Mac OS
Dynamics AX 2012
To use the Safari browser, you must install Microsoft Dynamics AX hotfix 2686124. Enterprise Portal supports Safari only for end user tasks in the portal. Enterprise Portal does not support Safari for developer or system administrator tasks.
The System requirements of Dynamics AX 2012 is in the process of being updated on Customer Source and Partner Source.
Follow the Dynamics AX Sustained Engineering blog for the latest updates on the above. For further information, feel free to contact daxsecom@microsoft.com
Dynamics AX Sustained Engineering: Announcing Compatibility Certification of SQL Server 2005 SP4 and Internet Explorer 9 with Dynamics AX 2009 SP1 Blog bot DAX Blogs 0 12.01.2012 09:11
Dynamics AX Sustained Engineering: Announcing Compatibility Certification of SQL Server 2008 R2 SP1 with Dynamics AX Blog bot DAX Blogs 0 15.12.2011 07:12
Dynamics AX Sustained Engineering: Announcing Compatibility Certification of SQL Server 2008 SP2 with Dynamics AX Blog bot DAX Blogs 0 18.05.2011 05:16
Часовой пояс GMT +3, время: 03:41.
