Старый 06.05.2015, 10:11   #1
DeniZone: Finding X++ compile errors from CIL compile log
Источник: http://denizone.blogspot.com/2015/05...-from-cil.html
Every once in a while you will get some strange errors in your code - in the pre-2012 R3/R2 releases of AX without the axbuild command, doing a full X++ compile is quite time consuming.
As known, without an error-free X++ compile, the CIL compile will fail, so how can developers easily find any X++ errors if the CIL compile fails? Sure, do the full X++ compile, but wait, there is more.
A quick way to find X++ errors after an unsuccessful fuld CIL generation is to look in the CIL generation log.
The log can be found on the AOS-server in the relevant AOS-instance's program files, e.g.
"C:\Program Files\Microsoft Dynamics AX\60\Server\[Instance name]\bin\XppIL\Dynamics.Ax.Application.dll.log"
You want the log to look like this
goshoom: Test Data Transfer Tool: Getting errors from log Blog bot DAX Blogs 0 12.01.2015 16:11
bojensen: Compile and CIL Generation errors when reporting extensions is not installed Blog bot DAX Blogs 0 25.10.2013 02:12
daxmusings: AX 2012's Hidden Compile Errors Blog bot DAX Blogs 0 07.02.2013 10:11
emeadaxsupport: In Microsoft Dynamics AX 2012, compiler output setting of Message Window may cause errors when generating (incremental) CIL Blog bot DAX Blogs 0 16.03.2012 23:12
daxmusings: Resolving Compile Errors and Generating CIL is not Optional Blog bot DAX Blogs 0 13.12.2011 16:11
Часовой пояс GMT +3, время: 05:20.
