Старый 28.03.2016, 22:12   #1
organicax: Basic constraint based configuration product and model setup.
Источник: http://organicax.com/2016/03/28/basi...d-model-setup/
If you are starting to explore setting up constraint based configured products then it helps to start simple till you understand how the models works and then add to it. The first thing you need to do is determine the questions you want to ask the operator that will effect the BOM or route of the product you are building. These questions then might have a list of values the user can select from, in AX these are your attributes. Once you have these then you can use them to make some logic decisions for your BOM lines.
Here is a quick walk through on creating a new product and simple configuration model
AX2012 R3 CU9.
Cheers
Lachlan
Filed under: Product information management
organicax: Reuse configurations on constraint based product model Blog bot DAX Blogs 0 28.03.2016 22:12
dynamics-coe: Override configuration ID in the constraint-based product configurator in AX2012 Blog bot DAX Blogs 0 29.04.2015 11:11
axmfg: Product Configuration: Setting values based on system variables - example, current user ID Blog bot DAX Blogs 0 29.04.2014 20:11
axmfg: Understanding the default configuration concept for constraint-based products Blog bot DAX Blogs 0 17.07.2013 14:11
DynamicsAxSCM: Product-item data management services Blog bot DAX Blogs 0 06.07.2011 17:11
Часовой пояс GMT +3, время: 14:01.
