Старый 04.05.2016, 00:15   #1
emeadaxsupport: Using the Current translation type in Management Reporter
Источник: https://blogs.msdn.microsoft.com/axs...ment-reporter/
Rates entered in AX for USD to GBP that will be used by MR when doing currency translation.         YTD/BB Column The report date is March 31st. The columns are set to return YTD/BB data. The data comes from the year end process run on 12/31 so uses the rate from that... Read more
emeadaxsupport: Using the Average translation type in Management Reporter Blog bot DAX Blogs 0 04.05.2016 00:15
emeadaxsupport: Using Currency Translation with Management Reporter and AX Blog bot DAX Blogs 0 03.05.2016 18:12
dynamicscpm: Consolidations and Currency Translation in Management Reporter Blog bot DAX Blogs 0 12.12.2012 00:11
dynamicscpm: Management Reporter and Dynamics AX currency translation Blog bot DAX Blogs 0 09.10.2012 23:12
dynamicscpm: Migrating to Management Reporter 2012 Blog bot DAX Blogs 0 24.05.2012 01:13
Часовой пояс GMT +3, время: 21:31.
