#1 |
organicax: WMS menu – movement by template
Источник: https://organicax.com/2016/05/11/wms...t-by-template/
============== In a previous post we have a look at the movement menu item. There is another option which is movement by template. The added advantage of using the movement by template is that you can use the work template and the locations directives to setup a process around the movement. Here is a quick overview. AX2012 R3 CU9 As you will see in this example the system is updated and the assumption is the physical stock is moved at the same time. There is an option to delay the move with the create movement parameter on the menu. Cheers Lachlan Filed under: Warehouse management Источник: https://organicax.com/2016/05/11/wms...t-by-template/
Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
