Старый 10.08.2017, 07:12   #1
organicax: Building a measure to publish to the entity store – Part 6
Источник: https://organicax.com/2017/08/09/bui...-store-part-6/
In our last post we created the query and the view. In this post we’ll now get to the aggregate measure. If you already had a view that you know has the data you need then obviously you would skip right to this point and create a new measure.
The point of the aggregate measure object is to actually create and link the measure and dimensions that you will use for analytics. The measure will be something you create and it will be a sum or a count of data. The dimension will be something you slice the measure by. This is the basic concepts in a star analytics schema.
Here is a quick overview.
D365 July 2017 Update 8 (7.0.4565.16211)
Once you have the measure then you can use it in Power BI desktop. From there you can published to Power.com and allow users to access it in the application. You can see how this works with the standard reports models in this post.
Cheers
Lachlan
Filed under: Business intelligence
organicax: Building a measure to publish to the entity store – Part 1 Blog bot DAX Blogs 0 10.08.2017 00:17
stoneridgesoftware: Part I: Configuring the Dynamics AX 2012 R3 Entity Store Blog bot DAX Blogs 0 27.04.2017 12:11
organicax: Working around the modifiedBy error when publishing an entity to the entity store Blog bot DAX Blogs 0 21.02.2017 09:11
organicax: Setting up an entity store in AX2012 R3 CU11 Blog bot DAX Blogs 0 21.02.2017 09:11
dynamics-coe: Microsoft Dynamics AX 2012 Reporting Services - Issue deploying OLAP SSRS reports on SharePoint 2013 Blog bot DAX Blogs 0 25.01.2015 12:17
Часовой пояс GMT +3, время: 00:33.
