Старый 14.09.2017, 13:11   #1
alirazazaidi: Custom financial Dimension shows in lookup D365 for Finance and operations
Источник: https://www.tech.alirazazaidi.com/cu...nd-operations/
I one of last post, I added the custom financial dimension in D365 for finance and operations.
You can find this post here
https://www.tech.alirazazaidi.com/cu...erations-ax-7/
In next post I load financial dimension in custom lookup.
Custom lookup for Financial Dimension D365 for Finance and Operations (Dynamics Ax 7)
But above link shows only out of the box financial dimensions. But what about custom financial dimension,
I tested the following code snippet works custom dimension. It load custom dimension mentioned in
Custom Financial Dimension in Dynamics 365 for Finance and Operations (AX 7)
[FormControlEventHandler(formControlStr(FrmTestDetail, FormStringControl1), FormControlEventType::Lookup)]
public static void FormStringControl1_OnLookup(FormControl sender, FormControlEventArgs e)
SysTableLookup sysTableLookup;
Query query;
QueryBuildDataSource qbdsDimensionFinancialTag;
QueryBuildRange qbrFinancialTagCategory;
String20 LC;
RecId _recid;
DimensionAttribute _attribute;
Name _name=’jaggah_tax’;
// super();
//#define.MyCustomFinancialDimension(‘LC’)
// select * from attribute where attribute.Name ==_name;
// recid = attribute.financialTagCategory();
query = new Query();
qbdsDimensionFinancialTag = query.addDataSource(tableNum(DimensionFinancialTag));
qbrFinancialTagCategory = qbdsDimensionFinancialTag.addRange(fieldNum(DimensionFinancialTag, FinancialTagCategory));
qbrFinancialTagCategory.value(strFmt(‘%1’, DimensionAttribute::findByName(_name, false).financialTagCategory()));
sysTableLookup = sysTableLookup::newParameters(tableNum(DimensionFinancialTag), sender,true);
sysTableLookup.addLookupfield(fieldNum(DimensionFinancialTag, Value), true);
sysTableLookup.addLookupfield(fieldNum(DimensionFinancialTag, Description));
sysTableLookup.addSelectionField(fieldNum(DimensionFinancialTag, FinancialTagCategory));
sysTableLookup.parmQuery(query);
sysTableLookup.performFormLookup();
FormControlCancelableSuperEventArgs ce = e as FormControlCancelableSuperEventArgs;
//cancel super() to prevent error.
ce.CancelSuperCall();
Output is here
sumitsaxfactor: Custom Financial Dimensions – D365 Blog bot DAX Blogs 0 10.09.2017 03:51
stoneridgesoftware: Filtering Lookup by Relation in Dynamics 365 for Operations Blog bot DAX Blogs 0 14.03.2017 00:13
dynaxtips: D365 Operations is available on-premise! …again. Blog bot DAX Blogs 0 25.02.2017 02:19
dynaxtips: D365 Operations on a Mobile phone Blog bot DAX Blogs 0 22.12.2016 15:11
sumitsaxfactor: Replace a Financial Dimension in Default Dimensions–Condensed [AX 2012] Blog bot DAX Blogs 0 23.11.2012 23:13
Часовой пояс GMT +3, время: 15:06.
