Старый 21.05.2019, 10:11   #1
fixrm: How to use spkl profiles do deploy different sets of web resources
Источник: https://fixrm.wordpress.com/2019/05/...web-resources/
If you don’t know, spkl is a great tool from Scott Durow which can really simplify your D365/CRM development process. Some aspects of how does it work are controversial, but I definitely recommend you to use it if you still don’t. So what’s the problem I am talking about? Some times you need to publish … Continue reading How to use spkl profiles do deploy different sets of web resources
emeadaxsupport: How to update AX 2012 Enterprise Portal in a multi-server web farm Blog bot DAX Blogs 0 09.11.2015 13:11
crminthefield: Building Multi-Purpose Silverlight Web Resources in Dynamics CRM 2011 Blog bot Dynamics CRM: Blogs 0 28.01.2012 02:16
Inside Dynamics AX 4.0: The Web Framework Blog bot DAX Blogs 0 25.10.2007 03:04
Pokluda: Outbound web service (AIF) Blog bot DAX Blogs 0 28.10.2006 17:43
Часовой пояс GMT +3, время: 00:08.
