Старый 04.07.2012, 18:09   #5
Konstantin Katsovich is offline
Аватар для Konstantin Katsovich
243 / 57 (2) ++++
Сообщение от spirius Посмотреть сообщение
если же запускается страница, лежащая в iis, то в .cs файле на строчке
Guid newContactId = service.Create(contact);
вылетает:
The server was unable to process the request due to an internal error. For more information about the error, either turn on IncludeExceptionDetailInFaults (either from ServiceBehaviorAttribute or from the <serviceDebug> configuration behavior) on the server in order to send the exception information back to the client, or turn on tracing as per the Microsoft .NET Framework 3.0 SDK documentation and inspect the server trace logs.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.ServiceModel.FaultException: The server was unable to process the request due to an internal error. For more information about the error, either turn on IncludeExceptionDetailInFaults (either from ServiceBehaviorAttribute or from the <serviceDebug> configuration behavior) on the server in order to send the exception information back to the client, or turn on tracing as per the Microsoft .NET Framework 3.0 SDK documentation and inspect the server trace logs.
заранее благодарю
Для сайте, который Вы создали выключите Anonymous Authentication
Читайте SDK!!!
Последний раз редактировалось Konstantin Katsovich; 04.07.2012 в 18:18.
crminthefield: Microsoft Dynamics CRM 4.0 and 2011 Update Rollup Release Dates, Build Numbers, and Collateral Blog bot Dynamics CRM: Blogs 0 24.08.2011 02:11
gustafwesterlund: 32 bit apps in 64 bit IIS 7 Blog bot Dynamics CRM: Blogs 0 12.08.2010 18:05
Ошибка 401.2 в логах IIS Digit Dynamics CRM: Администрирование 1 31.05.2010 16:52
gustafwesterlund: IIS Diag Blog bot Dynamics CRM: Blogs 0 08.01.2010 16:05
Изменение колонки identirier в IIS Aicha Dynamics CRM: Администрирование 6 27.03.2009 08:09
Часовой пояс GMT +3, время: 14:05.
