Старый 28.11.2017, 10:39   #1
skuull is offline
skuull
700 / 752 (27) +++++++
Вот в 12 починили таки
Problem
Unexpected client error occurs when using any personalization shortcut key in the Add a field dialog box
Description of change
When using the Add a field tool in personalization, a slider allows the user to select the fields that are needed in the form. When this slider is visible, the usage of any of the personalization shortcuts (for example, when trying to filter the list of fields) will result in an unexpected error. The changes modify the Add a field dialog box to no longer honor the personalization shortcuts, which allows a user to filter the set of fields without running into a client error.
За это сообщение автора поблагодарили: EVGL (5).
d365, d365 for operations, pu10, pu11, pu12
alirazazaidi: Custom financial Dimension shows in lookup D365 for Finance and operations Blog bot DAX Blogs 0 14.09.2017 13:11
organicax: Refreshing forms – options in D365 Blog bot DAX Blogs 0 14.04.2017 19:11
organicax: D365 applying application hotfix Blog bot DAX Blogs 0 11.04.2017 01:31
emeadaxsupport: D365 for Operation CSS Global support incident closure procedure for support incidents involving a bug Blog bot DAX Blogs 0 04.04.2017 22:11
organicax: D365 Warehouse app configuration settings. Blog bot DAX Blogs 0 31.03.2017 02:14
Часовой пояс GMT +3, время: 07:47.
